Geoff Weeks
Pedigreed Bulldog-
Days Won
7
Content Type
Profiles
Forums
Gallery
Events
Blogs
BMT Wiki
Collections
Store
Bisom truck lines newton IA
Geoff Weeks replied to Lmackattack's topic in Antique and Classic Mack Trucks General Discussion
Could you be thinking of Buddy Sombarts Marmon cabover? -
What model of axle
Geoff Weeks replied to Coulton's topic in Antique and Classic Mack Trucks General Discussion
Looks like I really goofed twice, the CRD 117, looks to be a newer version, but if you look at the primary reduction case, the CRD 78 is different than the 117. So I'll go hang my head and not lead you further astray. -
Sure, you can put an refrigerant compressor on anything with V belts. The condenser may take more work to fit, there are frame mounted condensers, of course roof mounts, which would be period correct. No :bolt on kits, but it is all possible. I built my own APU before they were widely produced, there are plenty of options in terms of parts to build a system, but buying a pre packaged parts, Red Dot makes many bunk units. IHC used under the passenger seat heater/AC unit that is very compact and is in the 1.5 ton cooling range and gobs of heat. Early (70's) 4300's had all the controls on the seat base, making it a complete unit that could be bolted to the floor pan, and would need 4 holes for coolant and refrigerant. The big question is if there is enough "head room" to put a passenger seat on top of the unit. Most newer cabs that take a full size air seat can, but trucks that used T bar or fixed seats, (lower profile) may not have the head room. Used parts, can be cheaper way to go.
Front pinion seal
I know nothing about this Mack axle (if you remember I thought it was an old Timken). That said, I would guess it originally had a graphite rope for a seal or a felt seal -
Another option would be a Red Dot bunk unit or an IHC under the seat unit, both would require some holes in the floor, but none in the dash or firewall. I think this is the way I'd go. I have a Mack sleeper with a Red Dot unit in it, they are very compact.
What kind of heater does it have? I have always thought that on a antique, you could add an electric coolant pump, isolate the coolant through the heater core, and use a tube and shell heat exchanger as an evaporator. Essentially making a water "chiller" then circulate the cold coolant through the heater core. I not sure how well it would work on an old leaky truck with an old heater that could barely keep it warm in the winter, but it wouldn't require any holes in the cab. As far as Ice or a swamp cooler, I don't think either would be good enough.
Mack 2v can it be changed to 4v?
Geoff Weeks replied to Dieselsmoke138's topic in Engine and Transmission
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi_gpvfmNCHAxVmmIkEHcRiNmcQFnoECCAQAQ&url=https%3A%2F%2Fwww.bendixvrc.com%2FitemDisplay.asp%3FdocumentID%3D7117&usg=AOvVaw3KGYmvyJKDfP8-cMomQB61&opi=89978449 This is Bendix's trouble shooting for compressors. I find that compressors get blamed when other things are causing excessive duty cycle. 15%-to 25% MAX duty cycle. One of the 1st things they mention is excessive air use/excessive duty cycle for any slobber issue. If you replace the compressor but the air use and/or duty cycle remains high, it will not matter new, rebuilt or the one you started with, they will all slobber oil. I didn't have trouble, and didn't need to change compressors for slobber, I had to change one for a loose main bearing on a 3406 Cat (front bushing for compressor crankshaft was loose.) attached is another Bendix .pdf on oil slobber TCH-001-045a.pdf -
just for you geoff weeks
Geoff Weeks replied to mowerman's topic in Antique and Classic Mack Trucks General Discussion
Sun (UV) and heat will age rubber badly. With a truck sitting in the sun with the tire exposed almost all the way around, the heat will build pressure in the tire during the day and lose it at night. The cycling every day up and down will age a tire sitting out for 20 years. You can see the rubber is "crumbling" just from sitting. -
It is not what it will hold overnight, it is how often it "blows off" going down the road that matters. I've seen leaks on the "wet" side, while the primary and secondary air tanks and components will hold overnight. Air line from compressor to the drier (if used) check valve in drier, air line to the wet tank, air line from the wet tank to other tanks, air line to air gov from wet tank, wet tank itself. air gov. All of those can leak and cause the compressor to keep cycling while the two main tanks hold just fine. I had one guy idling next to me in the truckstop, air system popping off every 15 sec, I told him he had problems, he said "I didn't know what I was talking about, his air system was the best in any truck he'd ever seen, stays rock solid on 120 PSI"! Best test I know, is run down the interstate at highway speed, when you don't have to touch the brakes for a while and time how long between when the compressor "blows off", Min acceptable to me is 10 min, 15 to 30 your just doing ok. 45 min and you have one tight air system. If you can pass that test, then you can condemn the compressor if it is still slobbering and the engine blow by is in check. -
Blow-by in the engine can effect the compressor, so I wouldn't condemn it until the engine is fixed and the air leaks are gone. Compressors are made for "duty cycles" meaning that much (way more than 1/2) of time they are (or should be) running "unloaded". If they are compressing most of the time, they will slobber. Every time I see a two valve Mack head, I think of how similar they look to a Leyland 680 head! I swear, somebody copied somebody else. -
Please do, spring brakes and weak air tanks, can do a lot of damage if mis handled. A tank that has rusted to the point that you can put a screw through it is very weak and can do a lot of damage when it explodes. Spring brakes can hurt you good if you try and take them apart without caging the spring.
Full cap and it will be fine LOL. Worse tire I ever had was a tubeless General, I had it on a chassie as a roller and it was just sitting in the yard when it exploded, Virgin casing, never been capped and the tread wasn't worn off it yet, Just blew while sitting! -
Bad air drier/ compressor cycling too much. How often does it cycle? A lot of time, spent in city stop and go traffic it will be hard for the best system to keep moisture out in the hot humid weather. One that is in poor condition will have no chance. Hooked to a trailer running down the road with no brake application, 15 minutes between the air drier blowing off is the minimum I like to see, I had one tight truck that would do 45. On the other hand I hear truck going down the road and cycling multiple times in one miniute!
2004 Granite CV713 AC not working
Geoff Weeks replied to shilohwestphal's topic in Electrical, Electronics and Lighting
Do you know for sure it hasn't leaked it charge? Bad clutch/clutch coil is a sign the clutch overheated. If it doesn't lock up with 12 volts to the clutch, I would suspect other problems as well. Some coils have a "thermal fuse" buried deep in the windings. If the clutch gets too hot from slipping, it lets go and keeps the belt from snapping. No way to replace/repair the fuse, you have to replace the whole clutch. If the system doesn't have a full charge there is a safety system Often a switch on the receiver that doesn't allow power to the clutch (as JJ mentioned). So, new compressor, which will require evacuating the system, and a recharge, then see if you have further problems. It may just be a loss of refrigerant. -
Weird radiator issue 427 asset ac
Geoff Weeks replied to Artful dodger's question in Mack Truck Q & A
Looks like one I had to deal with, someone listened to a old farmer and put "black pepper" in the cooling system to "cure" a coolant leak! Expensive "cheap fix"! -
I lifted him to the drivers floor and he scrambled up onto the drivers seat from there. When he was younger and more agile, he would jump onto my shoulders to get out. Later I had to get him a ramp, but with that, he only took a few steps down the ramp and then jumped off the side of it! Believe me! No one was more glad I retired then he was! Before him, Jesse was 76 lbs. I put him in and out the same way.
Last few years before I retired, I was alternating between my double bunk and single bunk Cabover with the dog house. I'm a big guy, over 6'3" and 260 lbs. I shared the sleeper with my 65 lb Chow/Great Pyrenees mix. I managed, but preferred the double bunk, or my Marmon walk-in.
It was the truck that really saved Freightliner, IHC and Freightliner cabovers were the pride of many fleets, or at least the main-stay. When the length laws went bye-bye, was right around when the FLD came out and they were well placed to take IHC's customers with it. Saw a lot of fleets go from IHC and Freightliner cab over to FLD's.
Sticker on the dash says it has a Rockwell trans? Not is common or trouble free as an RR (Eaton).
Mack T2060A trans and PTO configuration
Geoff Weeks replied to Deanmitchell78's topic in Engine and Transmission
It looks to me like the "extra' gear is a PTO gear for the 6 bolt mount on the side. This is interfering with the 8 bolt mount. can't tell if the gear pitch matches from just a photo. Mis match of parts, either start again or get a PTO for the exact trans you are putting in. PTO's are very limited in what they fit, they all look alike but there are 1000's of combinations of parts, that all have to be matched for it to work. -
Brakes howling and wheel lug nuts
Geoff Weeks replied to RS Disposal's topic in Driveline and Suspension
450 to 500 ft lbs on inner and outer stud pilot nuts. Brake noise is often dirt/ dust. -
Wiring up Led Pedestal lights
Geoff Weeks replied to Ricky Beals's topic in Electrical, Electronics and Lighting
This sounds like the ground is faulty, either the truck wiring or the lights themselves. Try running an external ground wire from a known good ground to the lamp and see if that solves the problems. You shouldn't need a relay with LED's -
Incandescent flashers depend on an amount of current being drawn on the flasher to work, LED's just don't draw enough to make it function. One 1157 with may be a dash indicator draw enough most of the time, but with all LED's the correct LED flasher is needed. BTW I have used flashers like you have successfully on 6 volt trucks, by stretching the spring on the relay inside. they work more on "draw" than voltage, if there is enough current draw they don't care about the voltage so much. LED's draw so little that they don't trigger the flasher to function. -
Do you have LED's on the rear as well? That flasher is for incandescent bulbs and may not work on LED's. Most times you can get by with it if one or the other (front or rear) has incandescent bulbs. Try getting a flasher that says it works with LED's It may have a ground wire on the flasher, I know some LED flashers do. -
Why the reliable dipstick is sliding into obsolescence
Geoff Weeks replied to kscarbel2's topic in Odds and Ends
When I was working at a dealership, we all hated the 1st oil change. I think it was the factory installed the filter dry (no lube on the gasket) and the metal was clean, caused the rubber gasket to bond to the metal. In some cases it took stripping away the metal "can" and filter element to gain access to the filter base plate, sticking a blunt punch in an air hammer and beating the baseplate loose. Yeah, do that in book time" ! If we saw a white painted filter with no markings, we knew we were in for a fight.
BigMackTrucks.com
Our Vendors and Advertisers
