Geoff Weeks
Pedigreed Bulldog
  1. When I got my Dart, I spent a lot of time trying to find info on CC and didn't get far. Since the Dart data plate was missing and the frame so heavily modified, I was trying to find another angle to "date" the truck. CC was a dead end, and the Stewart-Warner gauge panel came closest to dating the truck to the early 50's. I does have a Chicago Cab plate on it.
  2. McLaughlin Body in Rock Island, made a lot of cabs and stuff for the Military trucks, may be? They are or were still in Rock Island, Il last I knew. One reason I don't think Chicago Cab was involved as they seam to disappear around the same time, but the Comfo-vision cab continued into the late 60's. I haven't seen or heard of either truck mfg buying Chicago Cab, they just seam to fall off the radar screen. By the late 50's Dart was using other cabs, and were briefly absorbed into KW, then Unit Rig, then ??? CC may have made prototypes or may have had no hand in it at all. The Comfo Vision is like the Ford "C" Budd cab, that Mack also used for a short time, Did Budd stamp out all of them? I kinda doubt it. So many low volume Mfg used the Comfo Vision cab, whether they bought the stamping in knock-down form, or paid for the rights to make it, I don't know.
  3. IDK, I don't think Chicago Cab made it, They did make the cab on my Dart, however, and that was around the same time period. I haven't found a lot of info on Chicago Cab, other than they were on Elston st in Chicago. The shear volume of Comfo-vison cabbed trucks make it unlikely it was produced by a independent cab maker.
  4. Try owning a Marmon! "who makes Marmon?" Me: Marmon makes Marmon Other person: Yeah, but what company owns Marmon? Me Marmon Group Yeah but who owns them? I give up.
  5. If it makes you feel better I have done the same, I think anybody who has worked around tires long enough has done it. Lock on chucks, and the tire falling over or getting bumped or hose getting pulled, is all it takes.
  6. I miss the "good old days" when every car had a bumper jack, and the metal "foot" of the jack was just the right shape for breaking the bead on any tire! Line it up under the front bumper, install the jack and a few quick pumps (or ratchets) and the bead was off, flip the rim over and do the other side.
  7. Air drier still need a signal from the gov to the air drier. That means two lines, one for the air pressure from the wet tank, and the 2nd for a purge signal to the air drier. That line comes off the middle port. Same port that goes to the unloader port on the compressor. He may have one hidden behind the intake piping, I can't see.
  8. What I don't see (may be there, I don't see in the pictures) is a signal line to an air drier for purge. Does this truck have an air drier? Moisture and oil/gunk from the wet tank can get back to the governor if the tanks aren't drained EVERY day when in use, without an air drier. I, for one, can never be bothered to drain tanks every day. I had air driers on my stuff and never had a problem until the drier had some sort of problem. If you don't have a drier, they are not hard to install to limit future problems. You may get it to work by cleaning as Brocky recommends, but if you don't address the source of the problem, it may stick the next time you need the truck.
  9. Air governors from top to bottom. Old Bendix, Midland front, Midland rear, Bendix D-2
  10. D-2 Pretty much an air gov is an air gov, you can put any kind on there. Bendix, Midland, it doesn't matter.
  11. Next time it happens, disconnect the ABS actuator electrically while it is leaking, if the leaking stops, the problem is in the electrical portion of the ABS, if not, it is in the pneumatic portion and is likely crud in the air system sticking the valve open.
  12. Replace the gov, Unloader only gets air from the gov. Had it happen many times with stuff that sits. If compressor valves are stuck in the unloaded position it will not build air at all.
  13. Does the truck have traction control?
  14. To be clear, you lay the gasket over the item, feel for the bolt hole, put a larger ball bearing at the hole, and strike with a hammer. Then put a bolt shank or rod through the new hole, and move on to another. I like to do the holes 180 apart 1st to more accurately punch the rest of the holes. Even used on holes you already made, it cleans up the hole in the gasket paper.
  15. Put a ball bearing over the hole and strike with a hammer.
  16. I think you had two distinct problems, and the 2nd didn't come to your attention until you addressed the 1st. The MV-3 should not have fallen apart when removed, so there was a definite problem with it. The spring brakes shouldn't have taken close to a minute to apply with the loss of pressure in the red line of the trailer, problem #2. Good that you addressed both. The 2nd would fail a level 1 inspection if the inspector was any good. It would have resulted in an OOS for the trailer. The 1st likely would result in a OOS for the tractor, although it was only an issue when hooked to a trailer so should have allowed you to bobtail away for a repair. P.S. we ALWAYS like to hear results, it helps in future problem solving.
  17. I'm reaching a point in my life, that when Rory dies, I'm not sure I have another 15-16 years I can provide to a young dog. The only thing worse than my dog's passing would be for me to pass before him. I can't imagine how to make sure he would be cared for. My 2 dogs were over 1 year old when I got them. I think this time I would look for an older dog that needs a good home, and can be cared for in its older years. Only "puppy" I had was when I was growing up. While it is nice to be there from the beginning, there is plenty of love coming into their lives later also.
  18. If it is anything like the screens in Cummins engines, they are there to be easily and cheaply replaced, to protect parts downstream that are hard and expensive to replace if plugged with debris. Remove or defeat at your own risk. Is it in the EGR cooler line?
  19. So sorry to hear that. It is tough. I can't go through it with dry eyes. Buried one and the dog I have now isn't long for this world. The love they give their whole life doesn't make it easier but does blunt the pain long term, I have the good memories of all animals that have passed through my life..
  20. I don't know why, but the Rotochamber was like 10X the price of a clamp chamber, there isn't a lot more to them then the clamp type. They are smaller in overall diameter for the same area (type number) then the clamp type. There there were the true Maxi brake, where you couldn't cage the spring and there was no way to manually release.
  21. I am not familiar with those, and they don't have the "step" that the rotochamber does. I wasn't doubting you, I just saw what he pictured as a rotochamber. I don't think I've ever come across the Wagner, in my time, but don't claim to have seen it all.
  22. I don't know, the O/P listed a part number which is for a Bendix rotochamber. That Bendix looks identical to the chamber in the picture. There were piston chambers, most I've seen are for spring brakes. Piston compresses the spring brake, diaphragm for service. https://www.amazon.com/Bendix-101260N-Rotochamber/dp/B0BVYDKZ4B
  23. What did you see when you ran the test? With or without the hole in the web?
  24. It is not a piston that wears a ridge, If the can is solid and the screws come out, your good to go. There is no wearing contact between the piston and the outside, the bladder is a "rolling lobe" like an air bag on air ride.
  25. The "bladder" is about $200 +/- depending on where you get. Toss up between two Type 24's or one "badder" for the can. I would keep the rotochamber, but that is me.
