45 minutes ago, 609albert said:
Hi,Just a suggestion ,bumper might look better if the ends had a slight bend and if the  ends where caped
Bending C channel is not simple or  easy, an end cap would "finish" the end and be simple.
might find it easier to take right size pipe ; cut in half or what ever depending on desired look then weld into channel ; weld/ grind to appear as one piece. have time and patience; weld the pipe to back side of channel THEN slice top channel , bend around the pipe. will have one bent form on front with welding/ grinding on top/ bottom flange. looks excellent as is  also.
