I just went through the book i have, and i didnt see anything that showed different part numbers for different horse power ratings. I think that turbo, nozzles, and injection timing may be where the difference is made. But im not at all smart about E-6' s
https://www.bigmacktrucks.com/topic/75776-e6-engine-horsepower/#findComment-578857
When the engine went  to 285 315 they added the air to air box which you have and the web’s between the main bolts  which u also have ! 350 they added a water cooler section to the aftercooler !  There may have been some piston changes I am not aware of and also governor / fueling changes!
https://www.bigmacktrucks.com/topic/75776-e6-engine-horsepower/#findComment-578859
Do you have any pics of the water cooler etc ?
https://www.bigmacktrucks.com/topic/75776-e6-engine-horsepower/#findComment-578860
No sorry bro I don’t! Your core engine is fine you can go up to 315 with that ! The water section used to take up about 3 inches on top of the existing air to air !with a 1 inch tube in and out ath front of the box!
https://www.bigmacktrucks.com/topic/75776-e6-engine-horsepower/#findComment-578861
7 minutes ago, Nathanwhit1 said:
Says 300 on the paper work. I’m just in the middle of stripping it then will be rebuilding so was just wondering if there’s anything worth upgrading while I’m doing it
Stick with what you have ! 315 /350 are  ment to have a multi speed trans
https://www.bigmacktrucks.com/topic/75776-e6-engine-horsepower/#findComment-578869
Didn't the 315 and 350 use a different pump ?
https://www.bigmacktrucks.com/topic/75776-e6-engine-horsepower/#findComment-578873
3 hours ago, Mark T said:
I remember one pushed, and one pulled on the throttle shaft. Then again, I remember when a 350 was like the greatest thing (lol)......n they kinda were at the time
My 300+ has the flip flop linkage going to the pump so it can push instead of pull.
A new local FB friend pulls using a 285/300 and removes the intercooler in an R model.  Apparently this pump is " the pump" to run .  He turns it like 3000+ rpm, all stock bottom end.  Says it is no problem.
https://www.bigmacktrucks.com/topic/75776-e6-engine-horsepower/#findComment-578906
6 hours ago, terry said:
I can remember when the 285 horse was king!   Terry:MackLogo:
😳 You didn't dare call it a 285 back then.  A "300" ....you were proud as could be. If you drove a Mack around here with the air cleaner with the two ducts over and under....king indeed.
https://www.bigmacktrucks.com/topic/75776-e6-engine-horsepower/#findComment-578909
