The wrong pinion on the starter motor
The wrong clearance on the starter motor pinion to ring gear
Ring gear is badly damaged in one spot and this binds on the pinion
Starter shaft has no grease on it from new and is binding on the shaft
Paul
https://www.bigmacktrucks.com/topic/75511-mack-start-issue/#findComment-575529
11 hours ago, cfd511 said:
Hello all , have a 2000 mack rd 688 . I burned up the starter and replaced multiple times now . It seems the starter somehow is staying engaged and not releasing which is burning it up . Any of you guys have any ideas . Any idea what to test to find the problem
Start solenoid on the fire wall sticking?
https://www.bigmacktrucks.com/topic/75511-mack-start-issue/#findComment-575536
I have seen the relay stick a few times.  fjh, is on to something. Ive even seen them crank the engine after shutting the door, as if there was something loose inside it.
https://www.bigmacktrucks.com/topic/75511-mack-start-issue/#findComment-575537
