2000 mack rd688 brake help
Moparmike
Type 30 brake chambers only have 2 inches of rod travel before they bottom out, unless they're "Long Stroke" versions. If your brakes have 2 inches of travel when cold then the air chambers are bottoming out and not applying full pressure on the slack adjuster. Plus, when your brake drum heats up it will expand, requiring even more brake travel to apply the brakes. If your slack adjusters won't keep the brakes adjusted under 1.5 inches then I'd argue it's time to replace them, they're worn out/failing.
