Truck voltage problem
with cruise control off, flip the switch up to "set" and release.
then count the times the light flashes. it will be a two number sequence.
like 5 flashes, then 4 flashes.
that two number sequence will be the fault code. (5-4)
you then look up that code to find out what is wrong.
