Door window weatherstripping
Restoration specialties has all of that.  Even some with the stainless bead. They are fantastic and will send you samples to verify for before you buy lengths. I used them for the doors on my r model. I have a set of workers that I bought from watts of you need.
On 5/5/2020 at 5:43 PM, Quickfarms said:
I have to replace the drivers door on my 1975 RS685LT and I need to replace all of the weather striping, etc for both the vent window and roll up window.
What is a good source and part numbers?
For both doors, you need 4 pieces of Mack part number 440SX30A.
The 440SX30A is for the tracks on the removeable door panel, and the upper section of the door (you'll need to cut/shorten that upper piece).
You only use the included brass retaining clips on the removeable door panel tracks.
The vent window post felt is different, and is (was) sold under a vendor number 2795-170014005 (1 per vent window).
The roll-up window "wipers" are Mack part numbers 35RU223 and 35RU224 (2 each).
  • 2 years later...
