2 hours ago, j hancock said:
The B-53 was a weight saving mixer chassis that would be the forerunner to the DM model.  Usually had a heavy Rockwell front axle, power steering and a fish belly frame.
Dont you mean the r model. Thought the b57 was the forerunner to the dm
56 minutes ago, GreenGiant2 said:
Don't you mean the r model. Thought the b57 was the forerunner to the dm
Both the B-53 and B-57 were heading in that same general direction.  The B-53 had the fish belly frame and the B-57 used a straight frame behind the cab.
The BBC for the B-53 was 108" (same as a B-61) and the B-57 was 101" (same as a B-67).
2,625 B-53 models were built between 1962-1966.
281 B-57 models were made between 1964-1966.
1 hour ago, james j neiweem said:
It looks like mack B's never came close to Whites coup cab 92 inch BBC. That was there big selling point. I believe the white A cab 9000 was also 92 in BBC. Those were cramped cabs.
The B-67 with the flush mounted bumper and contoured cab featured a dimension of 89".
The measurements I used up above was for the standard bumper and flat back cab panel for straight truck use.
I think the White was a high cab short conventional or low cab forward, and would be compared to a Mack C model.
