If it's the old push mack style clutch you adjust the free travel with the outside linkage.  They had a spacer that was bolted in between the pressure plate and the flywheel that if it was slipping and had free travel you could take out and it would put more pressure on the clutch disc.  Some time it would work and sometime not.  Are you slipping or just need to adjust free travel.
  • 8 months later...
Years ago twaz told the clutch linkage is set  @ factory for delivery and the only time U need to adjust the linkage
is wen U take the gearbox out etc
and all clutch and clutch brake adjustments R dun in the clutch bell housing
WotSezU?
cya
