air build up rate in 2000 rd slow
mackr1989
Look for cracks n loose fittings Between the compressor n 1st tank
the 1st tank will have a one way valve to stop go n back to compressor.... Mainly wen the governor cuts in/out..... with engine off U may not hear any leaks at the compressor n 1st tank
also the above mentioned hose/pipe can get coked up with burnt oil  restricting air flow
with Macks U'll find bubbly n frothy water will soon find any air leaks
cya
§wishy
