237 air intake from air cleaner
Freightrain
Before I go building something I wonder if someone might have the plastic molded tube that turns 180* to hook the turbo up to the air cleaner?
Something along these lines:
I know the turbo is 3 1/2" diameter.  My air cleaner pipe in the firewall is 4".
I know it is kinda tight in a B model so this might not even work.  I don't have the fenders back on the truck yet so I can't "see" what I have to work with yet.  I hope to get them bolted on this weekend.
Found a better pic:
I suppose I could made the 180*, just need the flex piping and support/heat shield.
I may come up with something and just make it myself I just haven't got to that point yet.  Once I get the nose bolted back on it I will have a better idea what I need to have to make it fit.
Kevin I will let you know.  Thanks.
