Fill the resevoir first.... then with a helper attemp to blead the air out. start at the farthest wheel then work your way to the front. If your cant get anything to happen, you might as well start with a new master cylinder.
Your will most likely need the following componets
1. Brake Lines, both rubber and steel
2. master cylinder
3. new bleeder screws or just the entire wheel cylinders (depending on how much acetylene or propane your use.... :D )
4. Booster cylinder..
5. possibly brake shoes, springs, adjuster kits etc.
Good Luck!! :SMOKIE-LFT:
That's a good start- I'd fill the master cylinder up with fluid first, then check for obvious leaks, starting with the master cylinder, then the booster, then all the wheel cylinders. If all that checks out OK, check all the brake lines for leaks. If they're all good, and even if you have to rebuild or replace any of the above, you'll need to bleed the system to get any air out, and you should have a good pedal. You'll probably have to jack each wheel up and adjust the brakes with a brake spoon through the slots in the backing plates too in order to get a full pedal...(condensed version). If you're lucky, maybe all they need is bleeding,but something had to cause them go away in the first place. You need an assistant too, to help with this by pushing the pedal down while you look for leaks and especially during the bleeding process, unless you use a pressure bleeder. Hope this is a little help anyway-good luck with your project.
Make sure that the brake shoes are adjusted good first or you will be moving the pedal a lot without any resistance to build pressure. Invest in penetrating fluid and start spraying every bleeder.Do that for about a week. Be mentally ready to break a bleeder off, that way it won't surprise you when it happens.
#1 on A-model registry
2. master cylinder
thanks for the advice, the truck has a hydr -vac system with a reserve vaccum tank on the other frame rail, I traced the line back from the reserve tank to the engine and and found it disconned (a pipe line from a sort of regulator on the firewall ) the line from this regulator to the manifold is gone and their is a plug threaded into the manifold. I don't know why it has been disconnected. :unsure:
Probably because the Hydro vac is shot, and they wanted to eliminate the massive vacuum leak.
