Triaxle made into 10 wheeler
mackr1989
 Share
I'm looking to build a heavy 10 wheeler out of an rd triaxle. I want to buy one with a 20 front and get 58 rears for it. My only question is are the frames the same between a regular rd and an rdsx? I'm doing this because clean rd sx 10 wheelers are so hard to find.
For the main part yes. They will have different bolt patterns and you will need the cross member/insert that goes inside the frame.
Matt
Does the rd already have 58s or are you going to take one with like 44s and put 58s in it? Does an rdsx have a triple frame? I know that the 55/58 and up eagles attach from the outside in and the lesser ones from the inside out.
Why not just use the triaxle, saves on brakes and tires and oh yeah, you can haul more tonnage.
 Share
