e 9 air intake plumbing
gearhead204
the e9-500 I got came from a 1995 ch series, when pulling the eng. I found a 1/4 air line elbowed into a tee for the 3/8 line that supplys manifold air to the injection pump. the 1/4 line ran to a skinner valve mounted on the cab hood support the valve has a short line on the other port open to atmospheric pressure. and a 2 wire plug ,I cant figure out w.t.f. this is 4 its not big enough to dump manifold pressure in any volume [polish waste gate] any help please!!!! it appeared to be a factory install, never seen a factory puffer valve by-pass .
It should be the puff limiter pics help, at any rate get rid of it.
The 1/4" line was for the shutters,,,,Works off intake pressure as the boost rises the shutter open
Electrical plug is for water temp keeps shutters closed until temp comes up or when temp drops under no load condition in cold weather
As you may know a E9 is hard to keep up to temp in the cold
Thanks for hearing me out.
