Engine Cold, Engine Backfiring with enging brake
Doffer
My Engine brake isn't disengaging when its cold for some reason. When I am using the engine brake and then hit the throttle the exhaust makes a weird noise (kind of like the engine brake is still engaged, but only partially), blows out all kinds of smoke and bangs and pops blowing flames out the exhaust then the engine brake turns off and it runs normal. When the engine warms up, there is no issue with the engine brake.
Its a 1999 Mack RD688S
What is causing this ?????
Edited by Doffer
The jake is hard on the valve train no matter using it for shifting or decelerating I get about 350-400k miles out of them and about 600k out of heads got 661k on one truck with still original bottom end still has cross hatches it's all in the maintenance and a good driver is always a help!
