Another Serial Number Question
Hi guys, i was wondering if mack used the same serial numbers on trucks because my serial number is U685ST-11692 and one of the guys who had my truck said he had another u model and the serial number on that one was U685T-11692. and the only difference is that mine had a tandem rear axle originally and the other one had a single axle rear end. vinny
:bulldog1::mack1::MackLogo:
No they did not duplicate serial numbers. Either one of you have the numbers mixed up, either model or serial mumber, or someone has messed with one of the trucks. Check the serial numbers on the frame. I do not know where they are on the U model, but someone else on here will.
Mike
Mike
I have actually seen the scenario prior myself with two of grandpa's trucks. Both were built on the same order. Vinny's truck is a U685ST denoting it was built as a tandem. The other U685T was built as a a single drive axle. These are both original configurations. The models are different but the sequential build/serial number very well could be correct.
so Rob since my u model was built in canada would that mean the truck with the same serial number be built in canada?
Not necessarily so. A guess would be the same company, or dealership for stock ordered the chassis on the same production order. When they were actually built, together or not, I have no way to know.
I know grandpa ordered two R611's on the same day with one being a tandem, the other a single drive and they came in about three months apart but the serial numbers were just like you mentioned.
One model is a U685T other one is a U685ST diffrent models
Tom ~ Parts & Service Specialist
Watt's Mack Sales, Inc. 1-888-304-6225
U685 is the model number. T is a single axle tractor. ST is a tandem tractor. It started at 1001 serial number and should have continued sequentially no matter what letters were after that(S, T, SX, X...) I called Don Schumaker(Curator of the Mack Museum) who said that they did not make two truck of the same model with the same serial number. They each need their own identity. If one is a U686 or some other model they could have the same numbers afterward, but not just the T versus ST. He is looking thru the records of the U685T11692 and U685ST11692 just to make sure something funny did not happen, but it should not have. I have a B66 at home, B66T1194, but I do not have the serial number plate. It is on another truck which is titled as B66T1194, but on its frame rail it a B67T. The guy who rebuilt the truck used the doors and title off the B66. I'll let you know what Don has to say.
Mike
Trucks of the same model, even if they were built in another plant, (in this case Oakville Ont, Canada) still would not have the same chassis number. Generally speaking, Mack also would not split a customer order (GSO) between two different plants.
Also, the chassis number is assigned when the truck clears engineering, sometimes even several weeks before the unit is built, and it is very common that trucks had consecutive serial (chassis) numbers even though they were built weeks apart.
I had also been involved in an incident when a truck came into the dealership and the chassis serial did not match the door plate, and the MSO, and the dealer was required to actually X out the number on the frame rail and re-stamp it with a factory stamp set. I was suprised that the customer really didn't have much of a reaction, I expected a problem from him, but it never was.
See my Flickr photostream page
http://www.flickr.com/photos/96692978@N05/
I spoke with Don Schumaker again. He said there are not two U685's with serial number 11692. Flexivan placed an order for 21 U685ST's. They are all on one General Sales Order so all are spec'd the same. The serial numbers go from U685ST11675-U685ST11695. They were built in Canada. Get your buddy to check his frame rail. Since his is an S he is off by more than one or two numbers.
Mike
