Truck Arrived And I Am Full Of Questions
DCR
I've been lurking on the sidelines for a couple of months trying to learn about the B Model Mack. I am now learning how much I don't know! My truck arrived yesterday, a 1958 B61T converted to a dump. When I looked at it and kicked the tires and test drove it, the truck had a problem with batteries and not starting. Jump the batteries and it would start. The first thing I did when I got it home was check the belts. They were so loose that the fan would spin freely. I replaced the belts, jumped the batteries and it started. This morning it would not start again. Jumped the batteries and it started right up. I charged the batteries. Took it for a drive to the license bureau to have the VIN number checked (non Ohio title so VIN has to be verified) and get it registered and new title work. I thought that the drive would charge the batteries. Wrong. On way back home, light changed, quick stop and stalled the engine. Yes, I am not a truck driver. Truck would not start. Jumped batteries and it started. I checked the generator and it is not showing any output.
At this point do I replace/rebuild the generator or install an alternator? The existing batteries are 2 12 volt batteries. I understand the the factory setup was 4 6 volt batteries. Do I replace with two 12's or go back to the 6 volt batteries? I am calling on the brain trust for guidance as to what to do. I am sure that as I get into more items that I will have many more questions.
I am still leaning my way around this site so if this post in not in the proper thread I apologize.
Denny
330-550-6020
A "Mack Pack" Charter Member
I just (two weeks ago) went through the SAME thing you are...I went to NAPA and purchased a Delco 10SI 63 amp alternator and modified the generator bracket and viola...no more charging problems...also added a dash light so the alternator would "switch on", as it needs a resistance in line with a switched 12 volt input...
I am still dealing with two old undersized POS dead cell worn out batteries, but I am going to remedy that tomorrow! Two group 31 twelve volts with 1000CCA each...
My advice is to spend every night reading these forums, it is the only way to learn, just about anything you could want to know is here, and has probably been answered.
If the batteries have went near completely flat (discharged), you will probably need to repolarize the fields in the generator to set up the initial magnetic field to start it again. With the engine running about 1000rpm touch the "F" terminal on either the voltage regulator, or terminal on the generator itself with a wire from the positive battery terminal for just a second. It may just start to charging.
Rob and Leslie,
Thanks for the response on my not charging post. With Christmas, cold and snow, I have not had a chance to look at it yet. I've been reading many other posts on converting to an alternator and eliminate the old technology of a generator so will do that as soon as I can. I bought the truck to use and drive and not for show so I don't have to keep everything original. Many years ago my Dad had a Model A Ford and I remember converting the brakes from rod type mechanical to hydraulic. Wasn't original but sure stopped better!
I think I am also converting to a negative ground system and 12 volt starting in the future.
Denny
Edited by DCR
Denny
330-550-6020
Weather finally is cooperating and had a chance to re-polarize generator. Nothing happened and still not charging. I will now replace generator with alternator. Can anyone tell me what to do with the generator wires and the regulator wires? Thanks.
Denny
Denny
330-550-6020
Denny
Before you make the final determination to replace you might have someone sit in the driver's seat while the engine runs at a fast idle. Flash the fields again on the generator and have the person in the seat tell you if the ammeter deflects when you touch the "F" terminal with the battery positive jumper lead like before. If the generator is defective, the needle will not deflect. If the needle moves toward the positive side, you have a defective regulator, or interconnecting wiring between the two units.
Replacing the generator with a modern day alternator is not a bad idea, however there really is nothing wrong with a properly operating generator also.
A generator is easy to rebuild too, though I haven't done it for years. Can you even get new brushes for them anymore?
Very easily obtained as are the brush block holders, spring, bushings, roller bearings, etc.
