Geoff Weeks
Pedigreed Bulldog
  1. I agree with @fjh, check fuel pressure and diaphragm. I had one similar, came on quick, and got worse quick. changing fuel filters helped a bit but not enough. I my case it turned out the suction line was leaking air into it but not fuel out. Would show in fuel pressure reading or a sight glass placed in the fuel line near the pump. Just one of a few things that could be bad. In my case, not obvious to find but easy to fix. Fuel pressure, esp under load where the problem is happening, would help to narrow it down. A hand pump on the smoke limit device would be a good way to check if it is holding pressure or leaking right through.
  2. I am working on a mount for an air compressor, and have a few 5th's that I could make a drop on mount on the flat bed for moving my storage trailer. If I were to be serious I'd have to replace the hydrovac with an airpack then it could tow semi's for real! As I posted some time ago, it has a 16K hitch and will have an electric brake controller for running electric braked trailers. K-7's could be spec'd from the factory with air brakes, but so far have only seen a picture of one spec'd that way. During the war, there was a need for trucks that could pull semi's and many hyd equipped trucks were retro-fitted with a compressor and airpac in place of the hydrovac. It turns out that the Leese Neville alternator is too big to fit where the stock generator is, so I can either have an air compressor or the L/N on the left side but not both. May put the L/N on the 48 gin pole and move its 48 amp generator to the white truck, or may opt to put the air-compressor on the gin pole truck, but that bed is too high to pull most semi's and the gin poles would be in the way.
  3. Yeah, and why the '48 (blue green) doesn't have them. It can be done well, just not with what the P/O did on the '42 (white) truck. It has another cab and doors going on, that also have W/C mirrors. I think either are ok if done well. Small round does leave something to be desired, but it is also rarely out of the far right lane either!
  4. Small round on an extendable stalk would have been factory. You need west coast that can extend away from the door a fair bit as the cab is considerably narrower than modern beds that you might want. Mine has the double A frame and then a loop for the mirror, but it rattles and moves a fair bit. Guy used all thread between the top and bottom A frame. I could make it better but haven't yet.
  5. Which is all why I just put some grease on and take on a short road test. Always wise if running a tandem axle in gear to have both axles off the ground. It wasn't stated if single or dual, and I should have made that clear. when running, the rotation of the ring gear moves oil out the tubes, which keeps the bearing in plenty of lube, and why they don't run dry right after the seal starts leaking. Once stopped any excess (above the bottom of the tube) runs back into the bowl. Some applications it is not easy or possible to over fill. Grease and a road test, then let sit for a few min and check/fill to the correct level has always worked for me.
  6. The spinning of the ring gear move oil up and out the axle tube, You only need to make sure you have enough oil in the bearings until that happens. You can: lift the rear axle and run at speed with the tires off the ground. jack up one side enough to have the oil run to the other side, then jack up the other. My way was to put a good coating of grease on the bearings when installing, then when the job is done go out on the road at 50 mph or so, then come back and top up the rear axle with oil. Oil will dissolve the grease and do no harm, grease will lube the bearings until the oil gets there.
  7. Neatfoot oil could be a substitute. Just a little to keep the piston seals supple. http://www.90thidpg.us/Reference/Manuals/TM 9-1827B.pdf https://www.abebooks.com/Bendix-Hydrovac-First-Second-Series-Service/31992141638/bd best I can find at the moment.
  8. I found the DVD but the file is too big to attach. It is about 25 min of oil field operations. It says 1952 on that CD. 1.1GB in one file and 300 MB in the other. Film wasn't in great shape when it was digitized.
  9. I don't know if I can find it, but if I do, I'll see if it can be posted, not sure how I would do that.
  10. Those "Shields" were common on axles with greased bearings, it was an attempt to take any grease flung off the hub from reaching the brake shoes. They most often vent to the hollow spokes, so grease will end up on the inner rim and not on the brake. As Mowerman will attest, they weren't all that effective. Once oil bath bearings were the norm, they were almost 100% INEFFECTIVE! so they went away
  11. Also it had the Tru-Stop disk E brake on the driveshaft after the Aux trans, It was a twin caliper brake, the disk and calipers were gone but the operating linkage was all there, so pre-dates spring brakes, no air parking brake control on the dash, so one wasn't added.
  12. One can Date the GM Diesel by the two large bypass oil filters, that places it in the 50's sometime, later full low filter were added at the oil cooler. I has a Berg air supply button to pull trailers. IIRC the front axle has 18" brakes.
  13. Somewhere, I have the sales lit. When I 1st pulled it from the scrap yard, I dove deep into research on it. That was many years ago, and I can't lay my hands on the info sheets, but remember the general spec's The GM diesel was one option, as was a large Wauk and Herc, both on Butane. Transmission were 5 speed and 3 speed aux with power-tower. As I said, the winch and rear axles were gone, as was the aux and power-tower. I purchased a 4 speed aux for it. Best I can tell, mine was built around '53. Dart made "off road" trucks the "100" and "150 oilfield" (mine) were the smallest trucks they made (at that timeframe) and the only of "legal" dimensions. The GVW rating of the truck alone was either 60K or 66K (I don't remember all these years later), more than most road tractors today. The GM 6-71 was smaller than the big Wauk of the day There is no way to tell if mine was a "re-power" or spec'd with the 6-71, what is likely, is it is a replacement block. Only question is what the original block mfg was? The yard I pulled it out of was padlocked, left un changed, from around 1962, that much is known. I bought it from the son of the yard owner, when the town forced him to clean it up in the early 2000's There were lots of old trucks, but none newer then the 50's. H model Mack, a Diamond T (that today, I wished I had bought instead) most missing their rear axles. That means my Dart likely had a working life of less then 10years. That is why the body remained in such good condition, however the frame had been beat to hell. The front axle was moved back, the steering column and box relocated, so it entered the cab in a more vertical position, the clutch pedal/lever extended so the operator could turn around and run the winch from the drivers seat. Winch brake control is mounted on the back wall between the seats. The person that found this yard, and worked to find the trucks a new home, sent me a super-8 movie converted to disk of either my truck or its sister, working the Oklahoma oil patch in the 50's. The abuse the trucks suffered make a 10 years in the wildcatting oil field seam more like 50 years of more normal use. At one point mine (or its sister) were loading the draw-works, and the front axle was up off the ground at a 45 deg angle, and they didn't slow down the winch, next second, it came crashing down as the C/G past the rear axles! The Mack H model was beyond hope, but the Diamond T looked like it could be driven out if it had a rear axle. It was a lighter model, but I don't remember the number, Had a IHC medium six, (could have been a 269 or may be a 308) and the leather protectors on the hood corners will in good shape, the gauges (always a strong point on Diamond T's) looked perfect. I chose the Dart because of it's rarity and because I thought (and hoped) it would be easier to find a home for the Diamond T. There were 50's livestock and car carrier trailers, as well.
  14. Bolt still show as being available. I don't know what size so just did a "generic" search. https://www.fleetpride.com/parts/euclid-brake-lining/01tUZ000001qhxpYAA Have to look for lining blocks. Both will likely be a "special order" but you could have pride in saying I re-line my own brakes when I restored my truck! https://www.maxitrucks.com/products/4709-brake-lining-set-23k never mind, that brake block set say Eaton ES, but I bet they have others.
  15. That was and add on, it sits outside the hood/bonnet. Shop made. The triple air cleaner was a GM mfg part but where it sits isn't. Unfortunately it got hit when the truck was moved, and the cast aluminum cracked, but is repairable. It was set up to mount to the blower directly. The hood was modified from original, there is evidence of a vertical exhaust exiting through the hood on the right hand side. There is some evidence, like the air cleaner and exh that this was a re-power, although sales lit show the 6-71 as one of the engine options. The engine number is hand stamped in the block and one is "upside down", it has a rear mounted (gear driven) generator that the cab floor was "boxed in" around, that doesn't look like how the factory would have done it.
  16. AFAIK there is no advantage to bolt on linings, Bolt or rivet, either is fine. Cast shoes, unless cracked, or abused are great for those that re-line. They are the heavy duty option, and with core charge, I'd hang on them. I have one set of cast shoes in my core pile, unfortunately they are 16.5 x 6", which is not very useful. Q brakes, are fine in the wider sizes with two webs, I prefer pin brakes on the narrower sizes used on the steer axle.
  17. I haven't seen bolt-on linings in 30+ years!
  18. If your going to do it, and just one wheel, send your shoes off and have them re-lined, and have them order a hardware kit when the shoes go in. That way it all goes back together easy.
  19. 4515 is a common "Rockwell" shoe, you have "pin style" and cast, both of which makes it different than a 4515Q. I would not let those cast shoes go without being paid for. I know some people run them through a "hot tank" to clean, but with mixed results. Hobby truck, clean as best you can and let it go at that, or replace and be done.
  20. Not sure this is what you have or not, but is shows not only the shoes are available but the worth of the "Core" ! Don't let the cores disappear without a receipt for them! https://www.anythingtruck.com/product/510-SS4515CAST.html Abex Premium Relined Brake Shoe 23K GAWR FT4515CASTNS | FleetPride Check-out F-P core charge!
  21. Other may have better advice, Mack's are not my strong suite. Take the brake shoes and spring to your local parts house. get relined shoes and hardware kit. One broken spring will likely mean others are not far behind. Shoes that have soaked in oil for a long time likely can't be cleaned. Being it is that old, you may have to have your shoes relined, but IIRC they are cast, so should be no problem. Look at the other wheels, if you have to get re-lined shoes, might as well get them all done at once, rather than piece-meal. So far I've only been stumped once on a spring. I have been able to get all the spec's but no springs.
  22. @67RModel asked for some picture, these are lousy but the best I can manage. Only rust out is near the hinge on the LF door. Rear cab window slide down so you can work winch controls behind the cab. Window glass except windshield is all wrap in metal frame. I got new windshield and side glass soon after I pulled it to protect for the short time it was outside. Lots of hacking and welding on the frame, make it a good candidate for a frame swap.
  23. I've had several computer H/D problem so have lost a lot of pictures I had. It is now stuff in the back a my barn, likely to be passed on to someone else who can give it the love it needs. It was worked hard and then sat in a closed junk yard from the early 60's until I saved it from going to China in the early 2000's. Rears and massive winch were gone by the time I got it. Body is in great shape for its age, and likely the best thing is for a body swap to a new chassie. I'll try and get more pic's but they will not be great due to the location and stuff around it. Attached is a WAI from JOT. Mine has shop made "pit" fenders. That one has the fenders it would have come with from the factory. This picture might even be mine from its early days, IDK. edit: It is not mine, that has vents on the hood side panel, mine has louvers.
  24. The interesting thing in the 50's is, while the 6-71 2 valve at that time was rated at 200 hp (later improved breathing brought it up to 238) right smack in the hp range of all competitors, both gas and diesel, it doesn't seam to be found in many trucks of the time. Cummins had the 220, many gas engines in the 175-200 range. It lends credence to the story that GM wouldn't sell. P.I.E. experimented with a 6-110, which was a disaster, with the "pin wheel" blower, might have done well with the later Roots. The Buda 844 was the outlier and high HP engine of the day, but had trouble staying together and on the road.
  25. From the cab sheet metal( or sub frame) to the engine block and from the cab sheet metal( or sub frame) to the truck frame.
