Red Horse
BMT VIP
Everything posted by Red Horse
  1. Guys, Anyone have any recent experience with getting new cab glass cut? Only good piece of glass I have is the back window. So I'm talking windshields, vent windows and door glass. Appreciate any cost info anyone might have.
  2. If it had a 534 it was a 900, not an 800. I know you said the sheet metal was gone, but for what its worth, if it had a short cab-90 BBC- it would be an LN-900. If it had a long cab-106" BBC, it would be an L 900
  3. Ok guys- For the front springs $950 pr. (these are 14 leaf) rears $1210 pr rear Helpers 495 pr Helper brkts 179 total $2834 Keep in mind this is a 35,000 LB rear with torque rods each side and a center torque rd going to the cross member. But like the Fram guy said.."pay me now or pay me later".
  4. O'Dog, If you get lucky, you can find some nice ones. the B-61S I bought for the Cab (and as it turns out, engine and quadbox) Has a great looking set of springs- no rust between leaves. Of course when I go to sell it everyone says.."44 rears, dime a dozen!'
  5. Freighttrain- A timely post! I'm debating if I should replace the springs on my 60 B-68X. this thing has a 35,000 lb. Rad 111 rear and I'm going to put a 10' dump on it and use it. Springs for this puppy with helpers will cost me $1550 for the rear and about 700 for the fronts. Your pictures convinced me. In particular as I intend to put a load on it every now and then.
  6. Didn't think my first post went through??
  7. Guys, Thanks for your input. The motor is sitting in a box trailer and I will check it out Monday and confirm the stud sizes. Bob PS You might have seen this B-61s in the classified section of WOT a couple of issues ago. It was the red one in FLA. I was told it was an early 60's but was actually built in Sept. of 65. Hopefully that is good news. Was delivered by Birmingham Mack to a Lawrence Lucas. The original order for the truck was through Prentiss Mack, Lafayette Ind. and the customer was Davis Trucking but somewhere along the line, the order was assigned to Birmingham Mack and their customer.
  8. Guys- thx for all of your input. We pulled the engine and its sitting in a box trailer that I won't get to untill Monday when I can check out the head bolts. I'll Keep you posted. The truck was built in September 1965 so hopefully it has the new style head gasket . By the way, it was sold through Birmingham Ala. branch and original owner was Lawrence Lucas. One of the orders also indicates "Davis Trucking" as the customer and Prentiss Truck Sales, Lafayette Ind. as the dealer but that ticket was written in August and then the unit was assigned to Birmingham Mack in September. History is half the fun of these things. My B-68X was ordered in May 1960 by Albert Welch Inc. a good sized Boston Excavating contractor. They are still in business today and a buddy of mine isa field super for them. He mentioned this to one of the owners (grandson) whose comment was.."yeah- we probably still owe on it"! Bob
  9. Well guys I bought a B-61S for the cab and it looks like the 711 in it is in much better shape then my old 673. No smoke and it sounds great. I have no experience with 711's. I came into the industry in the mid 60's when my company still had 673's and then transitioned to Maxidynes. What should I be looking for and what should I expect? The engine is a 1965 and I'm putting it and the quadbox that came with it, in my B-68X . I will have a 10' dump on it and I intend to use it every now and then to grab a load of stone for my driveway and/or help out at the fairgrounds. The 673 that repowered this old gasser is like I said, a smoker and it is noisy- plus its a Duplex so I think 'm ahead with this swap.
  10. Guys, We have pulled the cab in prep for cleaning up the chassis. All of the rubber bushings are showing their 48 years of age. Any suggestions as to where you get these things? Same with trans (quadbox) isolators.?????
  11. Theak They are both double frames
  12. Well guys, I'm looking for a few opinions. I have a single axle B with 35,000 lb single rear axle. (RAD 111). I bought a tandem B-61 for the cab, but after looking at it, the engine is better then in my single axle plus its a quad box. In addition, even though its a tandem, except of course for the cross members, the frame rails are the same and the cab-axle dimensions are the same. I'm thinking, instead of pulling the engine/trans and the cab from the tandem, I perhaps should pull the big axles/wheels off the single axle and put them under the tandem. Biggest concern is redrilling the frame. As it was a tandem, it has plenty of holes associated with the center cross members. Plus the 35,000 lb rear from the single has torque rod hangars that would also have to be drilled out. Anyone have any thoughts on this?
  13. Guys, Well I did get my parts back. And I think the stuff looks good. One of the side dogs lost a bit of material on the edge and the "Mack" side scripts have a few pits. But the "Mack" that goes above the radiator shell and the dog bas and "the Dog" Look great. I will post some pictures when I get a minute- actually I took a before photo so I will stage the after the same way. Not sure Rod what the procedure was but all in all I'm satisfied. I alkso priced out the same items on Watts Mack and I saved about 225 plus shipping. I have no clue as to the quailty of the items Watts has as I assume its all reproduction but in addition to saving a few bucks I do know what roads my dog went down 40 plus years ago!
  14. Paul, The guy is actually a broker of sorts. He runs a speed shop and provides rechroming as one of his sidelines. the guy he uses is in rhode Island. This guy was referred to me by a guy who has an established powder coating business- not someone who would pass out endorsements casually. I haven't given him the green light but I probably will. Am I paying a bit of a "handling" charge? Probably. but I did say to the guy.."well why don't I just find a plater and cut you out as the middleman?" His answer was that he had purchasing power and a longstanding relationship with this guy. I kind of think the plater would rather not deal with a lot of people coming into his business with small orders. My guy on the other hand collects orders and brings them down to the guy so the plater deals with one guy vs the individual accounts. I know as a matter of fact with my parts he also was bringing down to the guy a set of front leaf springs for a "bucket T", as well as some assorted bumpers and grill parts. I will keep you posted.
  15. Guys, Well I have a hard number. $775 bucks will get me 8 pieces as follows: Nosing that "Dog is attached to. "Mack" header that is under the nosing on the rad shell Bull dog Right and left side hood dogs one "Thermodyne" one "diesel" one "B-61" Any opinions? PS- I also sent him my rad shell just for kicks- a grand! I think it will look nice in Black with redshutters and chrome hood latches!
  16. Theakers- thx for the input.
  17. Guys, Ca anyone shed some light on non- turbo 673 variations. I have a B 68X that someone at some point in time yanked the gas engine and put a 673 in its place. This engine is as basic as you can get. The street side of the block is clean with nothing but the intake manifold on it and two oil hoses that go to/from a Luberfiner. I also have a B-61S that is a 1963 and has a 673 thst is totally different. Instead of a single piece intake manifold, it has a split manifold plus what I believe is an oil cooler. Anyone have a clue as to the HP differences in these two motors?
  18. Guys, Thank you all for your responses. I tracked down a shop in my area and am going to bring all my stuff down to him next week. He says his minimum is $125. I gather that refers to what can fit in the basket or tank or whatever. I will keep you posted as I would think this is a commeon issue today.
  19. Anyone have any experience with getting their old B Model parts rechromed? Costs? Things to look for in a good shop? I'm talking about the hood lettering, the dogs on the hood panels as well as the "mack" nose piece including the Dog. My stuff has quite a bit of pitting.
  20. F'Train, I will try to post a picture if I can. Looks like it will not be the easiest thing given diameter of spring packs vs what is on there now. Bob
  21. Any ideas out there? My 61 B has an RAD 111 35,000 lb rear axle. The brake chambers are those big cans that are about 5" in dia. and about 6" long and they are on the front side of the axle. On the back side, there is a bar that connects the right and left slack adjuster. Existing parkig brake is the manual Orschlen lever connected to the drive shaft- not much for a single axle with a 46,000 lb gvw! My question is, what would the best way be to convert this to maxi chambers? Bob
  22. Duh! why did'nt I think of that. I have what was a B-68X that someone converted to a 673- left what I assume is original radiator in that did not have shutters. I just bought a 61 (for the cab and the 673 quad box) and the shutters and the shutterstat assembly looks good. Common sense would have told me that if I looked at it long enough. I also salvaged the radiator shutters and shell off of a junkyard B-42 -just before the shears got to it. and I have that complete assembly. Is the shutterstat rebuildable to any degree? Any info would be appreciated. Bob
  23. Guys, How does the shutterstat get its temp info telling the shutterstat to open or close?
  24. Guys, speaking of door seals, what is a good replacement product for the seals?
