12 hours ago, Jamaican Bulldog said:
How does a RD frame depth and thickness compared to a DM?
DM 400-600 frames are a little different because they have a belly. 13.37" depth in the belly and 10.75" when it straightens out through the tandem section of the frame.  .375" frame material thickness.  Insert frames were available as in double frame.  The insert did not have a belly.
DM800 are straight with a 10.62" depth and multiple inserts were available as well as outside frame plating to specifications.  .312" frame material thickness.
