Ac starter/ generator voltage
Mine are all 6 volt, I confirmed it on most of them by checking the light bulb numbers. Stop and tail was # 1158   6 volts. There is room to run a pair of 6 volt Optima batteries in series for added amps. I'm sure some have been changed to 12 over the years. Six volt systems also run bigger cables and wiring than 12.
Edited by 41chevy
Just curious, does your AC still have the reduction starter or  the direct drive starter? That does make a difference some what.
17 hours ago, ekennedy21 said:
Direct
Most likely up dated to 12 volt than.
