Hendrickson AIRTEK
kscarbel2
3 hours ago, Swishy said:
Brake the leaf n it'll put U off the road ....or in a ditch
have been know to limp back to our depot with a blok of timber hold n up the chassis on front axle ... th@'s with the 3 leaf front spring
WotSezU?
cya
Ted, when M-B introduced single leaf front springs on the Actros, they were actually introducing Hendrickson product. Hendrickson produces the most of the steel spring suspension for European truckmakers. Hendrickson continually developed better and better metallurgy, reaching the point where they can offer a durable and lightweight single leaf design. That said, if I was running the outback, I'd go with a 3-leaf design.
I know the folks at Hendrickson. Their ongoing research in metallurgy is impressive.
our CH 1998 Mack Has Air bag suspension on the tandem drive  (HAS 460?) POS
all OK in a straight line
it spins up a wheel go n round roundabouts
cant go over a roadside kerb with out losing traction
useless off road ............. not enuff vertical travel
not good for placing a full load on / off the drive by crane etc it bends the air bag top plate
had it all overhauld by the xperts @ $10k
no more airbags on truck drives 4 me
cya
I'll second this Lot Swish..
i have HAS460 under My (as you call it) 2 Story Renault & suffer from the same problems.
Giving serious consideration to letting these Guys have a Play with It..
http://www.thehairetruckandbusrepairs.com.au/hairebag-suspension
https://powertorque.com.au/the-haire-haire-bag-suspension/
Because those that matter...
don't mind...
And those that mind....
don't matter." -
Mack Titan with 3 leaf suspension .......so far so good
Pretty sure this is Ovlov suspension Swish..
have heard the Wodonga mob R good
they fit bigger plumbin to cure the problems
They do a Bit more that That Mate.
Like most clever Ideas it's; very simple what they do.. (They even have a Worldwide patent on It)
They connect the Air bags together via Large Air lines & install a valve that isolates the Air bags once the Height control Valve is Level.
Then (for instances) if you're reversing up a kerb when the rear Axle starts to rise air is transferred to the Front Air bags making It a true load sharing Deal Similar to a Walking Beam.
As apposed to normally when the rear axle starts to rise Triggering the height control valve to Dump Air & Whilst your waiting for this reaction to happen your front axle loses traction because It's swinging in the Breeze being Lifted by the rear axle..
don't mind...
don't matter." -
