polished aluminum
Dump truck has a polished aluminum body. spent quite a while to get it looking better.
BUT!!! water I use is hard. There is a salt system softener on it.
Problem is that the salt deposits leave a mess if not wiped down quickly.
Any product I can use to get rid of them....besides more Mothers?
thanks, Ed
You probably have a high concentration of TDS, (total disolved solids) and although the water is soft, it needs additional filtration to strip these from the water supply. A 5 micron final filter will do this but plug quickly. I would put a 50 micron, followed by a 10 micron, followed by a 5 micron to plug the larger and less expensive first. A 5 micron will remove color from water and all but trace minerals.
You won't have any "spotting" with this method.
I think I've seen things  made to just screw on your hose to filter the water your washing with to eliminate spots.    Idk if they work or not.   Just remember seeing advertised somewhere.
