18 speed gear split problems
mackr1989
mack 18 speed in a 2000 rd with a 400 doesnt always fully engage when splitting between underdrive and direct. it will happen wether the transmission is in high or low range. when this occurs, it will seem to just neutralize and grind. what is going on?
If its the splitter, its the top cover on the back box that possibly needs to have the air cylinder rebuilt (new o-rings, maybe new brass air fittings) and check the air lines and other fittings on top of the transmission.
