MACK E7 427 CX 613
teniente
Im voting freeze plug fell out of end of rocker arm shaft. Also, the bottom stud on the exhaust manifold on every ETECH style engine is drilled all the way into the push tube bore. Oil can leak past the treads and make it look like oil is coming out of exhaust manifold. A missing plug on the rocker arm shaft ( they just fall out sometimes) can flood the top of the motor with oil and cause too much oil in the push tube bores and oil seepage.
