Question about lowboy trailers
Im new to large trucks so still learning. How long of a neck does a lowboy generally have if used with a tandem axle truck? I found an old Lacrosse lowboy Im kind of interested in. The owner says there is 6' from the pin to the frame of the trailer. Is this enough be fit behind a tandem truck?
My truck currently has a flatbed bolted onto the rear but I'm thinking of putting a 5th wheel plate back on as thats how it originally came.
-Jeremy
Will your 5th wheel be a sliding one?You should measure from the center of the random to the rear of frame then add about 2 feet and you should be good.The other way you can check it is to have someone hold the end of the string line and you hold the other end and see how much you need to clear the end of the frame.
