Ideas for repairing the headliner plastic console Superliner
I started the process of redoing the interior pieces.
Has anyone repaired or used anything short of replacing the plastic console to fix it. Mine has a couple cracks and missing some edge where it screws to the roof.
Ideas welcome and I will let you all know if it worked for me.
Robert
I've use Fusor 141 plastic repair and aluminum flat stock as a backer. Scuff the back surfaces and aluminum with 24 grit then prep with wax/grease remover. Heat gun activates and helps it set fast. I use Fusor for MR doors, LE doors, and anything plastic interior or exterior.
any further info available on this product?
I'm also going to put my steps on that path.
That head liner front part has cracks and some small pieces over the screws missed.
So it will required not only form fixing but surface work.
It's like a leather outside and easy filling/sanding would make it flat.
Might be made applaying scratching but seems like alotta work without perfect turn out wich would worth the labour.
Any experience?
