Granite INFRAMED MOTOR
Yup, motor done in truck.
The most important deal is to have all the paperwork to back up "Motor In-framed". Paperwork would indicate bearings, liners, heads, pump, etc. Everything done should be listed and match the motor number and injector pump number.
Does the motor work have a warranty? Is the warranty transferred to the new owner?
Most motor work is done in the chassis unless there has been something catastrophic that has happened.
A man i know bought a used truck that had just been inframed, the oil pressure drop a few months later. Pulled the pan and a piece of grit was in the oil pump valve, simple fix, but #5 & 6 clyinders there was gobs of rubber glue around the bottom of the sleeves. I always wonder why You would spend the money to overhaul and than get rid of it. Like some one said be sure you get warranty and was done by a reputable place.
