shifting process on a Mack 12speed
mackniac
Hi !
need to have some advise on shifting a Mack 12 speed tranny .
many people are saying .
1- push clutch
2- pull stick on 1st direct
3- release clutch
4- apply fuel pedal
5- push knob on HI
6- release fuel pedal
7-push clutch
8- release clutch
9- apply fuel pedal again
10- push clutch
11- pull out stick from 1st to neutral and push knob back to direct
12-release clutch
13- push clutch
14- push stick in 2nd
15-release clutch
16- apply fuel pedal again
17- repeat process for each gear
then some goes :
1- push clutch
3- release clutch
4- apply fuel pedal
5- push knob on HI
7- apply fuel pedal again
8- push clutch
9- pull out stick from 1st to neutral and push knob back to direct
10-release clutch
11- push clutch
12- push stick in 2nd
13-release clutch
14- apply fuel pedal again
15- repeat process for each gear
then some others goes :
1- push clutch
3- release clutch
4- apply fuel pedal
5- push knob on HI
7-push clutch
8- pull out stick from 1st to neutral then in first again
9- release clutch
10- apply fuel pedal again
11- push clutch
12- pull out stick from 1st to neutral and push knob back to direct
13-release clutch
14- push clutch
15- push stick in 2nd
16-release clutch
17- apply fuel pedal again
18- repeat process for each gear
thank you to all for the help , it is very appreciated !
If I see you in Macungie I'd love to sy thank you in person !!
I will wear a Red Manitowoc baselball hat ! and a strong french accent !!! lol
Edited by mackniac
trannies are some of the easiest to drive. I'm not sure I've driven that particular version, but if it's an 8 speed, you'll have a 4 speed H pattern. What you'll do is put the selector in Low, the run through the gears, 1-4. After reaching 4, put the selector in High and shift back to 1, which now becomes 5. Run through 1-4 again, these now become 5-8. To downshift, reverse the sequence.With this tranny it sounds like you'll have 4 reverse gears too. To back up, select ® on the shifter, then select the appropriate gear. Avoid selecting (N) with the clutch released, you'll have a tough time getting back in gear without shutting the truck down.
