87 Mack Superliner
Does anyone know where the GVWR tag should be on the Superliner? On the door jamb is the VIN Tag with model number and VIN, but I can't find the weight tag anywere
Edited by bmking16
That tag should be on the door jamb. The only other place you would find that information is to contact the Mack museum and request a copy of the builders record. It should give a GVWR rating, and if it was built as a tractor, a GCWR rating. If your truck is a tractor, the fifth wheel was probably not done at the factory, it was likely done by the dealer. Whoever installed the fifth wheel should have supplied the sticker, sometimes referred as a certification sticker, or as a second stage MSO.
See my Flickr photostream page
http://www.flickr.com/photos/96692978@N05/
Thanks so much!!!!
