E7/b61 Heart Translant?
Hey fellas we have began the retore on the little B61 but i was curious what you guys thought of dropping a E7 mechanical 300 in her..the original seems to run great but i do have a complet E7 laying around...what s the pros and cons and the rate of difficulty thoughts and opinions please
..(oh and id be needing a transmission to mate to the E7)
well i know it wasn't hard when i helped do this one but for the life of me i can't remember exactly what we did to fit it in
I do know that the "Quad box" didn't last to long behind the "237" as he's since replaced it with a 10 speed air change
here's a pic or two
th_CamsBWpic.jpg th_100_0457.jpg th_100_0456.jpg th_100_0451.jpg th_100_0439.jpg
Edited by werkhorse
Well do you think it would be "Taboo" to pull the engine and bastardize it with the new plant or should i just give the stock plant a try? I do know she needs injector/pump work for sure and maybe rings who knows.
Edited by MACKMADMAN
A Mack is a Mack in my opinion. You could put one of those newer E7's in there with a new maxitorque and a new set of mack rears and it wont be a bastard.
-Thad
As was stated previously, my main concern would be where to put the charge air cooler without making it look like a butchered up mess.
There's no room in the radiator area as it is on a b61, trying to jam a charge air cooler in there ain't gonna work.
Why not preserve it in it's original form, with the stock engine & transmission?
Just my .02.
Just my .02.
Would the tipturbine intercooler from a E6 work on a E7 just wandering. Ron
correct me if im wrong but the exhaust header and intake runners on the 2 valve tip turbine have a diffrent bolt pattern than the E7s. If that is correct the headers and intake set up from a 2v will not bolt up to a 4v
I have seen E6 4VH with the tipturbine setup , awile back there was a post that said the oil pans were the same between the E6-E7s, the engines look simuliar i didnt know if anone has tried it. Thanks Ron
