Door Glass Replacement
Going to be ordering vent and door window glass from Watts...
Has anyone replaced these? What holds the glass in place?
What do you use to "mount" the new glass in the frame/regulator?
Thanks
heh,,good luck my friend,,,buy plenty beer,,glass sits in a thin layer of rubber insulation,,they probably have it at watts,if they dont try any glass shop,,install with soap,n water,,tap glass into rubber,,if in doubt let the glass shop put the glass in the frames,,,dont forget to grease n oil all moving parts to window regulater,,while you got it out..have a ball.lol.bob :whistling:
