Mystery Item
leversole
Wondering what this is? One line comes from a service port on the treadle valve, the other goes to the column mounted trailer brake lever, and it has the brake switch. All of the diagrams I have show the column lever gets full air from the tank. Why would the trailer brake test valve get air only when the brake pedal is pressed? Confused...
Thanks
Lever on the column is a trolley brake. Only works thr trailer brakes. Treadle works truck and trailer brakes.
When you pull on the trolley brake, the brake lites "should" come on-thus the switch.
Trolley brake was used as a parking brake, but could help slow you just a bit if needed.
The 'Trolly' brake lever (We call it the trailer brake or 'spike'), should NEVER be used as a parking brake. It can work it's way off by vibration of the engine or even simply ease off on it's own. It is not to be relied on for parking - use the buttons on the dash.
That being said, it's main use is for braking in slippery conditions, it will help keep a tractor-trailer straight - you can also apply the pedal brake and override it to apply even more braking pressure to the trailer - this takes some experience/practice.
It can also be used to back under a low trailer that doesn't have spring brakes, back up to the trailer, connect your air lines, pull the spike to apply the trailer brakes and then drive the truck under while the 5th wheel lifts the trailer.
Edited by speedy
Don't know if his truck has all the air buttons. 1965. Trailers from that era, did they have spring brakes?
Thanks
Looks like a check valve.
Thanks
It is a double check valve. Sends air to tractor protector valve. Connected to trolley and treadle. In a proper trailer hookup air lines are connected to trailer before trailer tips fifth wheel. Then trailer brakes are applied with trolley lever. As said before old trailers didn't have spring brakes. So without applying air brakes you could wind up chasing the trailer for quite a distance.
I though the main use of the Trolly was for when you were pulling someone else's trailer, you could wear out their brakes and save yours.
Works good with electric trailer brakes too.
