Geoff Weeks
Pedigreed Bulldog
  1. IDK, mine stay put. I don't trim until the straps are tight, and are just the width of the strap. Purpose made stuff is great, but I am going with what I have to hand. I've got stuff that has over 15 years on it and hasn't moved. If If had serviceable purpose made stuff, of course I'd use it. You could (and I have) used a little weatherstrip adhesive in the center of the strap to hold it, but I have also done it dry. Thinking about it, the times it worked best was on cylindrical tanks where the force on the strap was even all the way around. Rectangular tanks, the strap is less tight on the flat parts and more on the corners,
  2. Oh, and one thing I didn't mention but may be should have, when I did my swap, I went from 3.90's to 4.11'/ 5.63's, and my mileage went up. You can be too slow.
  3. Looked in the Red Dot online catalog, and it only lists R models back to 1980? so don't know what would be required to install on a earlier truck.
  4. I would doubt it had it from the factory. Period correct would be a roof mount condenser and either a roof or backwall mount evaporator unit. I don't know if the R cab kits I have seen will work with all years or only some years and not the other. Advantage of the correct dash mount is you should get fresh air into the unit and not just recirculated air. If the truck has shutters that may preclude radiator mount for the condenser (might not be enough clearance for the condenser and still have the shutters open) and would need a fan and shutter override on the system. All reasons why roof mounts were so popular back in the day.
  5. The heated mirrors On my IHC had a heater grid that had an adhesive on the back, it was a single use, and I don't think you can peal it off the old and get it to stick to the new. That is if you could get it off in one piece. I would see if replacement grids are available. Long time ago they were for my IHC's I doubt they are still sold that way anymore, Likely have to buy the whole mirror.
  6. I believe a few months ago Watts was selling the complete kit. I know Red Dot also makes a kit for the R model.
  7. I had plenty of used tubes and/or flap material laying around, so I would put it under the strap an the trim with a utility Knife, but some say I am cheap!😄
  8. My guess is the time and money will not be worth the trouble. I had about $3K total in my swap, but I did everything myself, and I already had a single axle parts truck with a 2 spd rear. I bought the front "core" and re ratioed both myself (purchased new ring and pinion for both). The housings in the truck would accept 2 spd in place of the singles with no change to the housings. I have the experience to replace gears and set-up a hypoid drive set. All that was done over 10 years ago. Look at your return on money spent and include down time in the figures. I doubt you could replace the rears like for like for that price. That is just for the "pigs" and no labor, using used "pigs". $3 grand pays for a lot of fuel.
  9. Well, that saves you replacing or sealing it, shouldn't need either.
  10. This is exactly where the BSFC graphs come in. In the old days a good truck salesman did the calculations for each truck, working with the buyer and the available options from the mfg. That is what YOU need to do. If you don't understand it, you need someone who not only does, but knows EXACTLY how you are going to use it. Basing you choice off what someone here or somewhere else says worked for them, will far more likely put you in a worse position then you are now. Modern trucks are often made to to best compromise and not "spec built" like they were in the older days. It can be the best it can be, as new trucks can handle wider operation than the older mechanical truck could. So if there is any improvement to be made, you are going to have to optimize for your exact need, or even know that there is no change that will yield better results. The time to work this out is before you plunk down dollar one on any change, not after you tried something and found it didn't yield the improvement you had hoped for. Getting it wrong may mean a slight improvement on the hiway but will tear up clutches and drivelines getting started, or may even give no advantage on the hiway and still tear up clutches and drivelines. That is why, as someone who has done it, I say do your homework! Been there done that and got the T shirt, I saw the results I saw exactly because it put the time in, and the results were exactly what the math predicted it would be. With modern electronic engines, they can do well in a broader range of RPM and load, so the answer you get may well be stay with what you have. I am not being obtuse or mean, I am giving you the experience of someone who actually has done it. There are no shortcuts that will give good results.
  11. Homework grade F! No one can answer that question without knowing how and where the truck is operating. the roads (or lack of them) and the loading and unloading under what conditions. You want simple answers and there aren't any. The mfg chose the ratio the truck came with, to fit the widest range of operation. That was a guess, if you want to optimize for your operation you HAVE to do the math and plot it out. If you are not willing or able to do so, save your money you would spend on a ratio change and put it into fuel, it will be the best bang for the buck.
  12. Only thing I'd add is DO YOUR HOMEWORK! don't guess, look at BSFC figures and base your desired operating speed to match that, realize often a small change makes big a difference, that is both good and bad, as if you are close but not right where you need to be, it could be a wasted effort. I did my Marmon and gained 3/4 to 1 MPG in my operation. I was mostly on hiway 65MPH and could make my selection based on that. I had a 15 spd Eaton that could handle the low end, but went with 2 spd rears anyway. I did a full spreadsheet, looking at starting ratio, and what it would do to hill climbing power, where the engine would be at differing speeds in all gears. When I did the swap, everything was where the math said it would be, made a much more "driveable" truck for my use. That said, I have heard from many that made swaps based on "what someone else said would be better" or a seat of the pants "guess" and were unhappy (not surprisingly) with the outcome. Your truck and engine are new enough you should be able to get the BSFC graphs, you need to really log your usage and look at all you need it to do, starting in soft ground etc. before making a choice. It may take more gears in the trans to make use of the gears in the back to their best. If you just slow it down in the rear, you may have trouble getting out of soft ground loaded. It is a whole system, and needs to be looked at that way. In my opinion, 10 spds have too much ratio gaps, but I was working on older, mechanical engines, designed for many ratio transmissions (13 or more gears). Still the starting ability on soft ground is still something you need to keep in mind.
  13. That is Canada, so likely 0.97 per liter. Gas was not anywhere near .97/gal in 1989.
  14. All my trucks had the starter and air start tank on the drivers side, but they were Cat and Cummins. I don't think you would put the air start tank on one side the the starter on the other. My '89 had dual 150's, but some O/O types ran more than that. Then theft becomes bigger risk.
  15. Old steel tanks like his and mine, USED to cost around $1.00/gal and Aluminum was $2.00/gal. I was in for sticker shock when I went looking before repairing what I had. They are very expensive now. I fixed what I had rather than pay the stupid prices. They were not all that much cheaper than the Aluminum one quoted above.
  16. Ok, someone put a newer tank on there. Step tanks up to the late 70's have the Tolhiem access plate, as both Ford and IHC big Gassers used that in tank pump. That tank is from a later year, when the gassers were no more and diesel was the fuel of choice. When you put it back, do yourself a favor and either get some strap webbing or make some by cutting an old inner tube to put between the strap and tank. Everything flexes and it will rust and wear a hole under the strap.
  17. Vlad, If his tank is like any of my step tanks, they have a plate on top for access to the Tolhiem pump that was original fuel pump for the truck. With that removed, there is plenty of room to get your whole arm in the tank. It is a large "D" shaped opening. My tanks tended to rust out under the "bands" and around the step area. I can take pictures of what I'm talking about, but it will be obvious once the tank is out.
  18. Bocky, you bring up something that happened to me last week. I was traveling to my brothers house in DMZ IA, and saw Love's had the cheapest unleaded. I pulled in and started to pump, no where around the grade selection buttons did it say anything other than "unleaded, Super unleaded and "premium" But on the top of the pump there was a little area that stated all fuel other than premium were 15% alcohol while "premium" was 10%. Around me, they have the alcohol content labeled at the selection buttons. I stopped pumping (I was driving a pre 2001, which is not supposed to have that much alcohol). Buyer beware! I buy Premium with no alcohol for my '84 Saab, 10% for my Toyota, The K-7 burns a lot when it is run, but gets run not much. Still that was, what I would call deceptive on Love's part. You can (and most stations do) put the alcohol content above or below the grade selection button. They have seen the last of my money!
  19. It is my understanding that the LV (as well as Ford SD) have in tank Tolhiem fuel pumps, no? so at least the evaporation problem that many of us struggle with (fuel evaporates from the carb, fuel pump) is a non issue and should prime quickly. I have similar step tanks on my K and similar rust problems. You can increase the filter size or keep many on hand. Clear filters can help see the problem before it plugs.
  20. I know more than a few oldtimer that never pull the wheels for brake jobs, doesn't matter if inboard or outboard, they pull the hub and wheels as one. If you are working on a smooth shop floor, a big piece of tin layed under the tires and slicked up with soap and water, just slide them out. I was always doing it in dirt, so would use my boom truck when I could. Trailer hubs you can't do that, but they make a slider tray for dual, which is slick. Quicker to pull the hub and wheels together and allows for bearing inspection also. Only down side is if you find you need a drum, with out board you have to pull them apart, in board it can depend.
  21. Kinda begs the question, what is the intended use of the truck? If you plan on using the 58's to their fullest, then stay with 24" TT, if you are not, but are still going to load the truck, I think those 58's would be an albatross in terms of parts when on the road. If it is a "hobby" truck then the 24" tires will out last your lifetime, so again no reason to change. Seams like a whole lot of money to spend if you don't need too.
  22. Then I'd say it isn't a common occurrence. I've had SP-4 spring brake valves on a trailer fail, and will not apply the spring brakes until all the air leaks out of the tank, I wouldn't use that to condemn spring brakes. It was a one off failure that can and did cause problems holding a loaded truck (tractor spring brakes were not alone strong enough on the grade it was parked on). Any truck with a driveshaft parking/E brake is subject to that failure, not just 2 spds. It was the reason that trucks got away from driveshaft brakes in general. I have repair more than a few snapped axle shafts, and most were on single speed axles, but they are more common anyway, so can't say why they snapped but it would point to operator error. Never snapped anything on stuff I owned.
  23. Yes, Paul you are correct. I didn't take the two posts as one connected incident. However my comment about spring brakes stands. most all tractors will have spring brakes on the wheel ends. It was why they were retro-fitted to older equipment still operating. Thank you for pointing it out. That said, I have never twisted off an axle shaft, and moved loads in 170,000 lb range, not much for some of your Roadtrains, but for the US considered heavy, BTW that was done through a 14" organic double disk clutch.
  24. In the above quote, I was talking about shifting the rear only. Like any compound shift, you need to take into consideration what is happening ratio wise. If you pre select a compound shift (moving trans and rear) like any other you can get caught with neither in gear. I will upshift the trans, and down shift the rear as I complete the shift. So double clutch upshift, when letting the clutch out when in higher gear, make the change on the rear. This means a larger drop in engine RPM to make the shift in the main but gets speeded up before load is on it. How wide the step also plays a part, My K's have a big step between 3rd and 4th, you need to downshift the rear making that jump, if you pre-select low range when you 1st break torque, there is nothing to speed the driveshaft up to match the rear low ratio to what the driveshaft is spinning. If the engine is against the gov, you can't speed up the driveshaft, so neither will go into gear. Kinda like shifting a 13 speed, make the main upshift 1st and the rear ( or in case of the 13, splitter gear)2nd. Sound more difficult than it is, but with a gas engine the ratio jumps tend to be bigger than with a close ratio box with a diesel. Most gassers have a 5 main and 2 spd rear, many diesels may have a 5 speed main and 3 spd aux. for the same ratio spread. A little time in and becomes 2nd nature.
  25. Fine then you are saying wait the decades for the money before doing anything! Companies will declare bankruptcy and courts will have to sell off what few assets there are. Neither Biden nor I am saying don't go after the company, but what is being said, is lets get going! We need the port open, and we need the roadway. If you want to wait until all funds are collected from other entities, the port will never be open again. We have already spent more money then the assets of the ship owner (responsible party) so are you suggesting we stop now? Think about it. I am not saying it is fair or just, but it is what it is.
