Geoff Weeks
Pedigreed Bulldog-
Days Won
7
Content Type
Profiles
Forums
Gallery
Events
Blogs
BMT Wiki
Collections
Store
New Mack Anthem
Geoff Weeks replied to james j neiweem's topic in Modern Mack Truck General Discussion
What hasn't changed a bit from the early days, is the number of axles to haul the weight and therefore the number of brakes to slow the load. 140K, 170K at 70MPH with the same brakes that were used when the speed was 1/2 that is not an improvement. More power will help get the load up the grade, but takes a good hand to get it back down the other side. I once pulled Butte, MT westbound and was one gear up from bottom, I could have used more power! only had a 315 HP at 1800 RPM gov limit, if that. Now we have big power, but still the same 7-8 axles and brakes under the same load. More power and the temptation to grab more gears and speed when pulling a grade instead of selecting a gear and riding it to the top, Much easier to do damage shifting under that kind of load on a grade, then taking more time and pulling to the top a bit slower. -
New Mack Anthem
Only thing that has changed, is the tolerance for slow moving large loads. -
New Mack Anthem
My DART oil field 150 has a 6-71 2 valve, they were rated at 200 hp! When they went to 4 valve they jumped to 238. -
New Mack Anthem
I showed up at a train de-rail, with a 6-71 (238 hp) Fleetstar, and was getting razzed, the old semi retired driver for the H-H company said "we used to move super loads with that power'. I used my Fleetstar because I knew I would have to go down an access road to retrieve the rail car. I took all the trailers down, turned them around and stretched them out for the other "large car's", on the understanding I would get the 1st load out! They ribbed me I could have the 1st load but would be last to be unloaded. The old gray hair said under his breath "don't you bet on it! You could here that 6-71 for miles, and I was the 1st to unload! -
New Mack Anthem
Pulling the same stuff we moved with 350-400hp! I moved the same stuff the oldtimers (at that time) moved with 200 hp! -
Not up on the newer stuff, but I know Meritor (Rockwell) made some double reduction units. There are two different capacities you need to consider, one is the housing and brake capacity and the other is the torque/reduction needed to move that. The double reduction were built like a standard front of a tandem with a high input and a bull gear on the pinion, but differed in that the drive ratio wasn't 1:1 from the input to the bullgear on the pinon. housing and brakes were higher capacity, allowing to carry more weight.
The switch allows you to quickly test that both are working, You should see an RPM drop when firing on only one, often around 50 rpm. Start on both, flip to one, then the other, to check and then back to both.
It could be as simple as one module on the bus not "powering up".
Canbus problems and digital stuff in general is not my strong suit. However, there are people with video's on the net that can help. It would seam, and I can be wrong, that something is bring down the bus. I think the way to test is resistance across the high and low canbus lines. If it is off, then start un plugging (disconnecting) modules until the one that is causing the bus to go down is removed. Again, I am very weak on this subject, but with multiple comm errors it seams to point this way. What you don't want to do is start replacing modules trying to hit the right one, that can get very pricey and takes longer than finding the one that is causing the buss errors.
1996 RD688 short to frame
Geoff Weeks replied to CrocEyes's topic in Electrical, Electronics and Lighting
If you are removing the ground, but leaving the + connected, then you will see a voltage between the frame and the - side of the battery. Esp if measuring with a digital voltmeter. The question is: are you seeing a draw on the batteries when everything is shut off? -
Alternator issues
Geoff Weeks replied to cruiseliner64's topic in Electrical, Electronics and Lighting
Paul, I'm embarrassed to admit I learned that one very late in life from someone else, but it does work, at least on the ones I tried it on. -
Ken, I wouldn't say it was easy (esp in stainless steel) but is doable by someone who can flare and braze. If you have your old one to use as a pattern, you'll not need a drawing.
Alternator issues
What I was looking for, was if there was battery voltage at the output stud. A test light is simple and easy to use for that. I wasn't concerned about regulator settings, as these type are fixed. either it charges to the set voltage or it doesn't. Another quick check you can do with the engine running is hold a small piece of steel close to the rear bearing, (A steel key ring will do) and if it is attracted to the alternator, you know the rotor field is energized. Once you know it is charging but have other problems a voltmeter is handy to have. A test light is quick and visual to see from a distance and almost impossible to mis-read. It will not tell the voltage, although if you "know your light" you can make an educated guess, but for work/doesn't work determinations it is a useful and rugged tool to have in your tool box. I wouldn't carry my Simpson meter with me in the truck, but I can diagnose most simple electrical faults with a testlight. -
I don't know what the MH one looks like, but for my cabovers I made a new tube from 1/2" stainless tubing. length is the critical dimension to get right. On mine the bottom end was a compression fitting and the top end was a bell mouth to accept the "stopper" end of the dipstick, it was a separate piece from the tube itself, and was brazed on to the tube, I heated, removed from the old tube and brazed to the new. Stainless tube is hard to bend, you could use plain steel tube, which is easier to bend. Trick to bend tubeing: make the tube longer than it needs to be by an inch or more. flare both ends with a flaring tool, after installing(temporary) flare nuts. cap off one end and fill the tube full of "sugar sand" tapping several times to make sure it is well packed, then install the other cap. With the tube packed with sand, ends capped off, bends can be made without kinking it. If you try and make too tight a bend you can still split it, but most bends can be made easily. When bent to fit, cut to length blow and wash any sand residue out of the tube, and braze on the bellmouth!
Alternator issues
I'm glad to help/ -
The type I think is supposed to have is what I have heard termed "vari-rate" spring pack, with a main pack and an aux pack above it, the top leaf on the main has the eye on one end to take the torque load. Very common single rear suspension. edit: may not be the top leaf, but one of the leaves in the main pack has the eye on one end.
Yeah,I saw the spring and thought "what the heck is going on here" but don't know Macks all that well, and don't claim to have seen everything so didn't say anything.
Alternator issues
This ad lists a bunch of interchange part numbers which may help in your search: https://kuwait.whizzcart.com/product/19384513/new-diode-trio-compatible-with-1a-leece-neville-79021-33-500-l79027-l79027hd-505202-l79027hd-1-33-500-1-l79027-1-171-16000/ I looked up 79021 and 79027 on my search. -
Alternator issues
Alternator issues
Ok, that is good news, You do have power to the alternator, so a wiring fault between it and the batteries is unlikely. In North America these are referred to as "one wire" type alternators, A bit of misnomer on the L/N because the case isn't the "ground" for the alternator. They "turn on" by residual magnetizem in the rotor producing a small amount of current in the stator, which runs through a separate set of diodes (diode trio) and is fed back into the field (rotor) regulator to turn it on. The regulator also is connected to the main output studs internally so when it turns on can supply battery to the field. The little wire between the two big wires is the feed from the diode trio to the regulator, to tell it to turn on. If your electrical guy doesn't know this, he may have supplied external power to that wire and the regulator turned on and worked. If that is the case the diode trio is the problem. It is the white piece that is connected to the three small studs and has the wire coming out of it to the little ring terminal up by the regulator. That trio is replaceable I am assuming (never a great thing) that he knows how to test the output current and main rectifiers when he did get to to charge on the bench. So assuming that is true it looks like you need a diode trio. -
Alternator issues
Test light will work fine, for seeing if he has power to the output terminals! There should be power there all the time, even with the engine stopped or the key off. -
Spoke hubs are part of the axle/brake combo. They are generally sized by the axle weight rating and the axle shaft design. So a hub on a DS402 the hub must fit the axle housing and the axle flange. The hub bearing size and placement is determined by the axle mfg. I used spoke hubs from a Volvo with a DS 402 on my Marmon with DS and later DT402's
- 1 reply
- 1
Alternator issues
If the light doesn't light across the two big terminals with the engine stopped, then you have a wiring problem. There should be 12 volts across the two big terminals at all times. I can see the - goes right to the block, trace the + -
Brake Shoe Headaches
Geoff Weeks replied to Mdmccurr's topic in Antique and Classic Mack Trucks General Discussion
Front brakes were optional on TRACTORS, at one time, I believe straight trucks need front brakes regardless of year. Edit, my bad, I thought this was the firetruck thread.
BigMackTrucks.com
Our Vendors and Advertisers
