B Model Radiator Cap
Mike
For the 673 engine what pressure cap poundage was or is used for the 673 with standard 48 quart radiator? I bought a 7lb. as was told by the NAPA truck parts person. The MACK Dealer said 10lb. Can someone clear this up for me?
Thanks
mike
The B model back in the mid 60 used a 5 or 7 lb cap. The 10 lb will not hurt the engine but may be too much for the rad. and heater.
Thanks
mike
I'll bet a 37 pound radiator cap would keep that coolant in there. Just place a 30 pound cinder block on top of the 7 pound radiator cap, and your problem is solved.
See, the solution is quite easy.
Hope you find this solution useful.
If it were my B model, I think I'd use the seven pound cap and be done with it.
:tease: Rob,
You would be great behind a parts counter at the local Auto Zone. And I also should build a fire under the truck to get the coolant and oil hot so it will start easier. LOL.............. Rob thats why we LOVE you when you come up with the best solutions. LOL.......... I'll post the results much later! Tell Momma hello from the BOYS...... LOL
mike
:tease: Rob,
mike
That solution uses the same mentality that the average AutoZone employee possesses.
I don't "darken their doorstep" because you only get paid to do a job once. Re-doing the same job because parts fail prematurely is the reasoning behind that statement.
