My '48 Int. KB-7 (Sanford)
Go to solution Solved by Geoff Weeks,
Sorry I didn't see that earlier.  I don't think there is a way that would give the factory result, if it would work at all.
For 12 volts, I would look at L/N and a SAE #1 mount. I don't know the cost, but you will have something that can be repaired/replaced easily.
 I am sticking with 6 volt so staying with the old Delco. I did try an new "aftermarket" armature and found them to work well.
