  • 0
are the crd150/151 and crd92/93 carriers interchangerable
Question
5 answers to this question
  • 0
Good question..  what year is the axle housing? I have not ever worked on 150/151 carriers, but I suspect they will bolt in.  Volvo did add a bolt hole the the axle housing , but i dont remember what year that happened.
  • 0
Yep. It has an extra bolt hole, but I believe you can mount the 92/93 set, and that extra hole will be covered. RTV is used to seal the carrier, so a leak is not a concern.  I expect others who deal with these to chime in.  I think the extra bolt was added later due to a common oil leak at the side cover area, where the 2 bolts would get loose.  There are no lock washers.
Answer this question...
