I was hauling gravel yesterday in my 85 r model and under load 4th gear kept popping out when accelerating. I could apply just a few pounds of pressure to the gear shift lever towards me and it would stay in like normal but if I held it forward it would keep trying to kick out.
Is there an adjustment that can be made to the linkage that will fix this or am I going to lose 4th soon?
Edited by Jizzo17
https://www.bigmacktrucks.com/topic/75785-mack-5-speed/
Well, i dont know of an adjustment. Unfortunately you will need to pull the main floor pan to get the top cover off to inspect the forks, and rails , and look at the clutching teeth on the 4th-5th sliding clutch. Is this a twin stick or do you have a blue range button on the shift knob (T-2070)? Or just a straight 5 spd.?
https://www.bigmacktrucks.com/topic/75785-mack-5-speed/#findComment-579012
Posted (edited)
It is just a straight 5 speed. It won’t do it all the time. There is just a range of engine rpm and travel speed that it wants to pop out.  Which is very close to the rev match to float into and out of gear.
Edited by Jizzo17
https://www.bigmacktrucks.com/topic/75785-mack-5-speed/#findComment-579013
Yep, as the others have said, lift the lid and have a look
Hopefully it will be something simple
Don't use silicone sealant type of deal when putting it back together
Just use gasket goo and some gaskets if needed
Silicone types of deal ooze out and break off and end up blocking oil galleries and getting caught in the sliding dogs, then the whole box ends up apart to clean the mess up
Good luck
Paul
https://www.bigmacktrucks.com/topic/75785-mack-5-speed/#findComment-579053
Pull the right seat, un hook the throttle hiem joint, there is a ring of bolts around the pan, 1/2" or 13mm. You will pull the shifter back into a gear, and lift the pan and twist it out..  if this is new to you, it will seem cumbersome, but it will come out.  The throttle pedal stays on the pan.  Of you still have the heel plate for the pedal, the little screws will likely fight you.  This is a good time to drill them out and get new speed nuts and screws..
  • Thanks 1
https://www.bigmacktrucks.com/topic/75785-mack-5-speed/#findComment-579089
