Coolant filter head for aset/ai motor question
Go to solution Solved by Onyx610,
I have realized the filter manufacturers list a coolant filter for my aset/ai motor.
My Mack main/lube book states that this is an option on these motors.
 I guess I should find one and bolt it on there right?
Can someone please post a pic and part number on here. Thanks.
Vmac mentions about overcharging the coolant with SCA which is true. However there is a Mack coolant filter and a Mack coolant filter with conditioner (sca). It has a bunch of sca tabs in it.
Some of these had a front redesign type water pump arrangement. Which the filter would be mounted at the left rear side of water pump. In that case inlet and outlet check valves must be installed with the direction arrows on the filter casing. If it’s at the front of the coolant manifold just do what i originally posted.
Edited by Onyx610
More info
