1956 mack b42sx with a en402 gas engine
jim1305
The clutch brake is not for shifting while moving. It's for stopping the tranny when "stopped" so you can select a starting gear.. ie: 1st. rev. etc... may I suggest double clutching....  My silly way is to count... one-onethousand-- two...on 'two' i grab the next gear...
9 hours ago, Maddog13407 said:
in all my years i have never seen a 77 series trans with a clutch brake. 67, yes and rare. double clutch it. its not a diesel and they dont shift anywhere near the same
You said a mouthful!  Double-clutching a gasser takes a little more practice than a diesel.  I suspect it has to do with the rate at which the revs rise and fall.  Passes by the sweet spot a little quicker.
