Superliner Door Disassembly
I'm  doing some door repair and had quite a struggle to remove the glass and all the operators and linkage from the door. Does anyone have  step-by-step instructions for re-assembling the working? Any advice would be helpfull.
I've pulled one of mine apart. From memory, after I got the door lock and the square shaft out it came out pretty easy. Another member on here gave the advice to do one at a time, in case your stuck you can go from the other as a guide.
Hope that helps some.
6 minutes ago, Plowboy said:
Practice? My wife said I needed practice. Not sure what she was talking about.
If she says you need more pratice you better get some more "things" to pratice on.  Apparently 1 isn't enough.
