JD160 Posted September 10, 2016 Share Posted September 10, 2016 Just got spindles back from the machine shop after having bushings reamed I think the pin is too tight, I have to tap it in w a hammer and wont turn by hand How tight should the new pin be in the new hub bushings Quote Link to comment Share on other sites More sharing options...
0 blackdog2 Posted September 10, 2016 Share Posted September 10, 2016 Brass or Steel use a small hone on a drill for wheel cylinder !! Quote Ed Link to comment Share on other sites More sharing options...
0 j hancock Posted September 10, 2016 Share Posted September 10, 2016 What is your front axle number? It will be stamped on the right side near the spindle and start with FA. Depending on which one you have it will be .0005-.0020, .0015-.0070 or .0025-.0045. Quote JimIt doesn't cost anything to pay attention. Link to comment Share on other sites More sharing options...
0 JD160 Posted September 10, 2016 Author Share Posted September 10, 2016 found 3QHF525B-P1 3QH38D-P and some smaller numbers closer to spindle kinda hard to make out Quote Link to comment Share on other sites More sharing options...
0 BOB DINGSDALE Posted September 10, 2016 Share Posted September 10, 2016 thats the axle part number. should be FA----- around same place Quote Link to comment Share on other sites More sharing options...
Question
JD160
4 answers to this question
