Brockway model builders
41chevy
Dave Natalie at AITM has come out with the conversion. Paul
http://www.aitruckmodels.com/pages/ck115brockway361.html
That's good Brockways are modelled.
What do you need to convert into Brockway using this kit
I personally would use an AMT/ ERTL reissued DM600 but the Autocar, Reo will also work. The DM will give you the Camel back, the square fuel tanks and battery boxes. The Autocar gives you the Rockwell AC-6W suspension and the REO gives you walking beam. Paul
Nice model kit for Husky fans.
Don't understand the ribs on the hood other than the center hinge. Just don't recall seeing them on 361's.
Daves are usually very accurate but being resin they easily sand off. Don't really know the Husky ins and outs.
The ribs are there just not a pronounced, After sanding, primer and paint they will be to scale. Here is Tom Millard 361 hood shot.
http://imagizer.imageshack.us/v2/1024x768q90/822/o0sn.jpg
Are the hood ribs correct? I ended up ordering a few projects from Dave this afternoon. Paul
No Huskiepup by any means,but I have seen 361's both with and without the ribs in the hood,not sure if it was done for added strength?.................................................Mark
