B model cab removal & air lines
The one on the left is a reservoir for the shutter cyl oil.The one on the right is a air compressor governor which can be replaced with the newer model of D2.To lift the cab remove the steer wheel from its shaft and slide a wood 4 by 4 thru the door opening with the doors opened and use a over head hoist.
Yes,DO NOT put the 4X4 through CLOSED B model doors(or any doors for that matter)! Like Glenn says. Common mistake. It turns good doors into junk! Al
