Transmission specs question
gicknordon
My dad has a 1987 mack tandem dump truck. The t- 2060 transmission was run low on oil and either needs replaced or rebuilt. The guy he usually take his transmissions to says it might be worth it to get a reman or rebuilt since running it low on oil might have changed the temper on the smaller gears. My question is is there any other make transmissions that will fit the same as the 2060. I read somewhere that the 2070 would fit, but i want to make sure of this first since a local truck parts place has a few 2070's but no 2060's.
