I have a 1987 Superliner with a 12 speed. It does not shift into high side when the transmission is cold. After I run it for an hour or so it will click into high side on all the gears, and run fine the rest of the day. What can I do to fix this issue, or should I take it to the Mack dealer? Any thoughts would be appreciated. Thanks!
Edited by Farm Man
https://www.bigmacktrucks.com/topic/23512-12-speed-high-side/
Rebuild the shift cylinders on the transmission top cover as they are leaking internally when cold. I would also rebuild the "selectair" valve, (shifter handle) while at it. Your problem is common as those transmissions age.l This is an easy repair but do consult a service manual before breaking things apart.
https://www.bigmacktrucks.com/topic/23512-12-speed-high-side/#findComment-104463
