DM690 six wheel drive - super singles
Olivetroad
I saw this truck today while truck shopping. It would make a good off road log truck!
Did Mack build their own four wheel drive front end or did someone like Marmon build conversion kits for them?
Fabco or Marmon I believe.
Mack built the trucks. Mine has an Eaton front end and Mack transfer case
I've seen a few AWD Mack mixers with Mack Transfer cases and Mack style front diffs too, same pumkins as the rears but in a steer banjo. The rubber looks like Military pattern.
Thats a DM? looks like the DMM style set up. Could be wrong though....my kids say I'm always wrong :(
AHH SOO....I'm DMM foolish not to know that..
Mack used to build the DMM complete as a 6 X 6 from the mid 70's. They were some of the first trucks to have early ABS (POS) Thay stayed the same untill I believe the 90's when the owners realised that that front axle and transfer case took a lot of load away from them, so Mack build the RD with a long wheel base and shipped them to Quebec to have a second steer axle put under them. They also had Meritor axles with PD lock amd axle locks and Chalmers suspensions for better traction.
Mack is in Ontario , Canada.
It could be from Canada, built at the Oakville Ontario plant. The trucks built there had a maple leaf under the Bulldog on the door. The one above may have had body work done
do you mean the bulldog on the bottom left of the door? i never knew that. maby i should put one of those on my truck cause it was built in oakville.
  • 2 months later...
