Disc Type Parking Brake Adjustment On An "a" Model
fxfymn
My Type 75A fire truck is equipped with a disc type of parking brake. The pads are "chattering" against the disc when I let off of the power. My Mack manual does not cover this type of brake so I was wondering if anyone has any advice on how to adjust the brake to take the play out of the pad assemblies.
Yep, it's a disc. I ended up having to totally disassemble it because I believe the chatter is being caused by either a bad transfer case bearing or bad drive shaft carrier bearing.
I'm going to have the pads relined and go from there after I get the transfer case issue fixed. I'm stil interested in hearing any recomendations on the correct adjustment procedures.
I have the same type of set up on my F.W.D. pumper. I'll have to crawl under there and study it for a while, maybe I can lend some advice. (oh that is scary.....)
